Both sides previous revision Previous revision | |||
projects:crazyflie2:expansionboards:multiranger [2018-10-23 12:56] kristoffer |
projects:crazyflie2:expansionboards:multiranger [2021-06-24 16:14] (current) kimberly |
====== Multi-ranger deck ====== | ====== Multi-ranger deck ====== | ||
The multi-ranger deck gives Crazyflie 2.0 the ability to sense the distance to objects around it with mm precision, up to 4 meters away. It contains 5 VL53L1X ranging sensors facing the front, left, back, right and up. When used together with the Flow deck the Crazyflie 2.0 can autonomously move around and avoid obstacles. | The multi-ranger deck gives Crazyflie 2.0 the ability to sense the distance to objects around it with mm precision, up to 4 meters away. It contains 5 VL53L1X ranging sensors facing the front, left, back, right and up. When used together with the Flow deck the Crazyflie 2.0 can autonomously move around and avoid obstacles. |
