projects:crazyflie2:expansionboards:proto [2016-01-26 00:47] fred |
projects:crazyflie2:expansionboards:proto [2021-06-24 16:12] (current) kimberly |
- | ====== Prototype expansion board ====== | ||
- | The prototype expansion board allows | + | <WRAP center round important 60%> |
+ | [[https:// | ||
- | Both through holes and SMD components can be soldered to the board. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. | + | ====== Prototyping deck ====== |
+ | The prototyping deck allows electronic circuits to be attached on Crazyflie 2.0. | ||
+ | Both through holes and SMD components can be soldered to the deck. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. | ||
The two pad rows that are closest to the expansion connector are connected to the connectors. | The two pad rows that are closest to the expansion connector are connected to the connectors. | ||
Line 19: | Line 25: | ||
===== Detection memory ===== | ===== Detection memory ===== | ||
- | If you want your prototype | + | If you want your prototype |
