projects:crazyflie2:expansionboards:proto [2016-03-30 14:26] bjorn [Detection memory] |
projects:crazyflie2:expansionboards:proto [2021-06-24 16:12] (current) kimberly |
- | ====== Prototyping expansion deck ====== | ||
- | The prototype expansion | + | <WRAP center round important 60%> |
+ | [[https:// | ||
+ | ====== Prototyping deck ====== | ||
+ | The prototyping | ||
Both through holes and SMD components can be soldered to the deck. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. | Both through holes and SMD components can be soldered to the deck. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. |
