projects:crazyflie2:faq [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyflie2:faq [2016-03-09 02:00] fred [Can't I use a normal R/C transmitter?] |
Line 32: | Line 32: | ||
==== Can't I use a normal R/C transmitter? | ==== Can't I use a normal R/C transmitter? | ||
- | Currently you can not but we plan to develop expansion boards with R/C receiver support. | + | <del>Currently you can not but we plan to develop expansion boards with R/C receiver support.</ |
+ | This can be done with the [[projects: | ||
==== How durable is the Crazyflie 2.0? ==== | ==== How durable is the Crazyflie 2.0? ==== | ||
Line 41: | Line 44: | ||
==== Can the Crazyflie 2.0 be used to control a bigger quadcopter? ==== | ==== Can the Crazyflie 2.0 be used to control a bigger quadcopter? ==== | ||
- | Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi... | + | <del>Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi...</ |
+ | Yes, it can. => | ||
+ | [[projects: | ||
==== Can the Crazyflie 2.0 fly autonomously (aka. autopilot)? ==== | ==== Can the Crazyflie 2.0 fly autonomously (aka. autopilot)? ==== | ||
Line 57: | Line 64: | ||
==== Can I do FPV (first person view) flying with a Crazyflie 2.0? ==== | ==== Can I do FPV (first person view) flying with a Crazyflie 2.0? ==== | ||
There is ongoing development in this area: | There is ongoing development in this area: | ||
- | * [[http:// | + | * [[https:// |
+ | * [[https:// |
