projects:crazyflie2:faq [2016-03-09 01:55] fred [Can the Crazyflie 2.0 be used to control a bigger quadcopter?] |
projects:crazyflie2:faq [2021-06-24 16:58] (current) kimberly |
- | ====== Frequently Asked Questions ====== | + | <WRAP center round important 60%> |
- | This is where we try to collect the most frequently asked questions | + | This page has deprecated |
- | + | </WRAP> | |
- | ===== Questions ===== | + | This page has moved [[https:// |
- | ==== For how long can it fly? ==== | + | |
- | It can fly up to 7min and depending on how you fly it, the time will decrease. | + | |
- | ==== How is it charged? ==== | + | |
- | It is charged using a standard micro-USB connector commonly used by smartphones. You probably have one of these cables at home. You can charge it from any USB unit that can supply 500mA, most computers and adapters do. It takes up to 40min to charge and the blue LED (M3) will tell you roughly how charged it is by how long it is lit. When it is fully lit it is fully charged. | + | |
- | ==== Can I hot swap batteries? === | + | |
- | Yes, you can hot swap batteries. | + | |
- | ==== Can I use a bigger battery? === | + | |
- | Yes, as long as it is not to heavy, it is a single cell (3.7V), it fits and that the polarity is correct you can do so. A higher capacity battery will give you longer flight times but will also decrease agility. We recommend batteries with at least 15C continuous discharge rate. | + | |
- | ==== What radio is used for the Crazyflie 2.0? ==== | + | |
- | The Crazyflie 2.0 can be controlled with the [[projects: | + | |
- | ==== Which mobile devices work with the Crazyflie 2.0? ==== | + | |
- | Here is a list of requirements for the mobile device | + | |
- | * Bluetooth Low Energy (BLE) or sometimes called Bluetooth Smart support. | + | |
- | * Runs Android 4.4 or newer | + | |
- | * Runs iOS 7.1 or newer | + | |
- | Since Android is available on many different devices, it is not certain it works even though it fulfills the requirements above. We have therefore created a [[doc: | + | |
- | ==== What is the radio range? ==== | + | |
- | As with all radio communication it depends. It depends on the environment, | + | |
- | * Crazyradio: Up to about 100 meters range in the 250 Kbit mode. (The uplink, Crazyradio, is the limiting the range) | + | |
- | * Crazyradio PA: Up to about 1000 meters range in the 250 Kbit mode. (The downlink, Crazyflie 2.0, is the limiting the range) | + | |
- | * Mobile device: Up to about 20 meters range. (The uplink, mobile device is limiting the range) | + | |
- | ==== Can't I use a normal R/C transmitter? | + | |
- | Currently you can not but we plan to develop expansion boards with R/C receiver support. | + | |
- | ==== How durable is the Crazyflie 2.0? ==== | + | |
- | The Crazyflie 2.0 is using the PCB itself as the frame. The PCB is made of [[http://en.wikipedia.org/wiki/ | + | |
- | ==== Is the Crazyflie 2.0 backward compatible with the Crazyflie Nano? ==== | + | |
- | As for the communication protocol, yes it is. So all libraries that have been made in Python, Ruby, C, C++, Java, etc. will be able to control the Crazyflie 2.0 the same way. The firmware is also intended to be backward compatible but we are not there yet and we can't promise anything before we have something working. | + | |
- | ==== Can the Crazyflie 2.0 be used to control a bigger quadcopter? ==== | + | |
- | Yes, it can. => | + | |
- | [[projects: | + | |
- | ==== Can the Crazyflie 2.0 fly autonomously (aka. autopilot)? ==== | + | |
- | Not yet, but there is ongoing development in this area: | + | |
- | * using onboard sensors (e.g. the barometer in the 10-DOF version) to achieve a "hover mode": http:// | + | |
- | * using extra sensors (e.g. an ultra sonic sensor): http:// | + | |
- | * using external sensors (Camera, Kinect, etc.) | + | |
- | * [[http:// | + | |
- | ==== How can I build an autonomous swarm of Crazyflies? ==== | + | |
- | * Before dealing with an autonomous swarm, maybe deal with one autonomous | + | |
- | * Not yet a swarm, but at least two Crazyflies flying next to each other -> [[https:// | + | |
- | ==== Can I do FPV (first person view) flying with a Crazyflie | + | |
- | There is ongoing development in this area: | + | |
- | * [[https:// | + | |
