projects:crazyflie2:hardware:externalantenna [2019-09-11 09:29] tobias created |
projects:crazyflie2:hardware:externalantenna [2019-09-11 09:45] (current) tobias |
| Line 38: | Line 38: | ||
| ==== What external antenna to use ==== | ==== What external antenna to use ==== | ||
| The antenna should have a mating u.FL connector, 50ohm impedance and in the frequency range 2.4-2.5GHz. Other then that choose one for your needs. | The antenna should have a mating u.FL connector, 50ohm impedance and in the frequency range 2.4-2.5GHz. Other then that choose one for your needs. | ||
| + | ==== Future development ==== | ||
| + | Being able to select antenna in run-time would be nice. After that things like antenna-diversity (selecting the best antenna at the moment) could be implemented. | ||
