projects:crazyflie2:hardware:spareparts [2014-12-24 07:21] chad Add schematic label for female (board side) battery connector. |
projects:crazyflie2:hardware:spareparts [2021-06-24 16:33] (current) kimberly |
+ | ====== List of spare components ====== | ||
+ | Below is a list of some of the components on the Crazyflie 2.X and where to get new ones in case they break. | ||
+ | * **P1 - Micro USB port**: ZX62-B-5PA(11) [[http:// | ||
+ | * **P3 - Debug Adapter Connector**: | ||
+ | * **P5 - Female Battery Connector**: | ||
+ | * **SW1 - Power Switch (CF2.0)**: B3U-3000P [[http:// | ||
+ | * **Male Battery Connector**: | ||
+ | * **Y1 - Chip Antenna**: Johanson Tech. 2450AT18B100 [[http:// | ||
+ | * **X3 - Quartz**: Epson TSX-3225 16.0000MF18X-AC3 [[http:// | ||
+ | * **P7-P10 - Motor connector**: | ||
+ | |at findchips.com]] | ||
