projects:crazyflie2:hardware:spareparts [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyflie2:hardware:spareparts [2021-06-24 16:33] (current) kimberly |
| ====== List of spare components ====== | ====== List of spare components ====== | ||
| - | Below is a list of some of the components on the Crazyflie 2.0 and where to get new ones in case they break. | + | Below is a list of some of the components on the Crazyflie 2.X and where to get new ones in case they break. |
| * **P1 - Micro USB port**: ZX62-B-5PA(11) [[http:// | * **P1 - Micro USB port**: ZX62-B-5PA(11) [[http:// | ||
| * **P3 - Debug Adapter Connector**: | * **P3 - Debug Adapter Connector**: | ||
| * **P5 - Female Battery Connector**: | * **P5 - Female Battery Connector**: | ||
| - | * **SW1 - Power Switch**: B3U-3000P [[http:// | + | * **SW1 - Power Switch |
| * **Male Battery Connector**: | * **Male Battery Connector**: | ||
| * **Y1 - Chip Antenna**: Johanson Tech. 2450AT18B100 [[http:// | * **Y1 - Chip Antenna**: Johanson Tech. 2450AT18B100 [[http:// | ||
| * **X3 - Quartz**: Epson TSX-3225 16.0000MF18X-AC3 [[http:// | * **X3 - Quartz**: Epson TSX-3225 16.0000MF18X-AC3 [[http:// | ||
| + | * **P7-P10 - Motor connector**: | ||
| + | |at findchips.com]] | ||
