projects:crazyflie2:index [2015-02-25 10:55] arnaud [Development] |
projects:crazyflie2:index [2017-01-25 12:54] tobias [Expansion decks] |
+ | ====== Crazyflie 2.0 ====== | ||
+ | The Crazyflie 2.0 is a versatile flying development platform that weighs only 27g and fits in the palm of your hand. | ||
+ | Its advanced functionality makes it ideal for developers and its Bluetooth low energy (LE) capability makes it easy to fly from mobile devices. | ||
+ | With its small size and weight, it's ideal for indoor use, but can just as easily hover above your house as | ||
+ | it can hover under your dining room table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled | ||
+ | by simply attaching the motors to the circuit-board frame, then it's ready to fly. | ||
+ | Before using the product please read the [[projects: | ||
+ | **Features** | ||
+ | * Durable design | ||
+ | * Easy assembly and no soldering required | ||
+ | * Supports expansion decks with automatic detection | ||
+ | * Supports flying from iOS and Android with Bluetooth LE support as well as from Windows/ | ||
+ | * Tested to above 1 km radio range line-of-sight (LOS) with Crazyradio PA | ||
+ | * Wireless firmware update | ||
+ | * On-board charging via standard uUSB | ||
+ | * Dual-MCU architecture with dedicated radio/power management SoC for advanced applications | ||
+ | * Real-time logging, graphing, and setting of variables as well as full access to the available expansion decks with use of a Crazyradio or Crazyradio PA and a personal computer | ||
+ | Have a look at the [[projects: | ||
+ | ===== Using ===== | ||
+ | * [[projects: | ||
+ | * [[doc: | ||
+ | ===== Development ===== | ||
+ | *[[doc: | ||
+ | *[[projects: | ||
+ | ===== Expansion decks ===== | ||
+ | ===== Electronics ===== | ||
+ | * [[projects: |
