projects:crazyflie2:index [2016-02-23 15:48] macke [Expansion decks] |
projects:crazyflie2:index [2019-02-18 17:06] tobias [Using] |
- | ====== Crazyflie 2.0 ====== | + | ====== Crazyflie 2.X ====== |
- | The Crazyflie 2.0 is a versatile flying development platform that weighs only 27g and fits in the palm of your hand. | + | |
- | Its advanced functionality makes it ideal for developers and its Bluetooth low energy (LE) capability makes it easy to fly from mobile devices. | + | |
- | With its small size and weight, it's ideal for indoor use, but can just as easily hover above your house as | + | |
- | it can hover under your dining room table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled | + | |
- | by simply attaching the motors to the circuit-board frame, then it's ready to fly. | + | |
- | Before using the product please read the [[projects: | + | This page contains information about the hardware design and advanced development topics for the Crazyflie 2.X. |
- | **Features** | + | For specifications of the platforms see below: |
- | * Durable design | + | * [[https://store.bitcraze.io/ |
- | * Easy assembly and no soldering required | + | * [[https:// |
- | * Supports expansion decks with automatic detection | + | |
- | * Supports flying from iOS and Android with Bluetooth LE support as well as from Windows/MacOSX/Linux with the Crazyradio or Crazyradio PA | + | Before using the product please read the [[projects: |
- | * Tested to above 1 km radio range line-of-sight (LOS) with Crazyradio PA | + | |
- | * Wireless firmware update | + | |
- | * On-board charging via standard uUSB | + | |
- | * Dual-MCU architecture with dedicated radio/power management SoC for advanced applications | + | |
- | * Real-time logging, graphing, and setting of variables as well as full access to the available expansion decks with use of a Crazyradio or Crazyradio PA and a personal computer | + | |
- | Have a look at the [[projects: | ||
===== Using ===== | ===== Using ===== | ||
- | | + | * [[projects: |
- | * [[projects: | + | |
- | * [[doc: | + | |
===== Development ===== | ===== Development ===== | ||
- | | + | *[[projects: |
*[[projects: | *[[projects: | ||
- | *[[projects: | + | |
- | ===== Expansion decks ===== | + | |
