User Tools
Site Tools
projects:crazyflie2:index
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
projects:crazyflie2:index [2016-02-23 15:48]
macke [Expansion decks]
projects:crazyflie2:index [2019-09-11 08:51]
tobias [Electronics]
Line 1: Line 1:
-====== Crazyflie 2.====== +====== Crazyflie 2.======
-The Crazyflie 2.0 is a versatile flying development platform that weighs only 27g and fits in the palm of your hand. +
-Its advanced functionality makes it ideal for developers and its Bluetooth low energy (LE) capability makes it easy to fly from mobile devices. +
-With its small size and weight, it's ideal for indoor use, but can just as easily hover above your house as +
-it can hover under your dining room table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled +
-by simply attaching the motors to the circuit-board frame, then it's ready to fly.+
-Before using the product please read the [[projects:crazyflie:safety|safety instructions]].+This page contains information about the hardware design and advanced development topics for the Crazyflie 2.X.
-**Features** +For specifications of the platforms see below:
-  * Durable design +  * [[https://store.bitcraze.io/products/crazyflie-2-0|Crazyflie 2.0]]
-  * Easy assembly and no soldering required +  * [[https://store.bitcraze.io/products/crazyflie-2-1|Crazyflie 2.1]]
-  * Supports expansion decks with automatic detection +
-  * Supports flying from iOS and Android with Bluetooth LE support as well as from Windows/MacOSX/Linux with the Crazyradio or Crazyradio PA +Before using the product please read the [[projects:crazyflie:safety|safety instructions]].
-  * Tested to above 1 km radio range line-of-sight (LOS) with Crazyradio PA +
-  * Wireless firmware update +
-  * On-board charging via standard uUSB +
-  * Dual-MCU architecture with dedicated radio/power management SoC for advanced applications +
-  * Real-time logging, graphing, and setting of variables as well as full access to the available expansion decks with use of a Crazyradio or Crazyradio PA and a personal computer+
-Have a look at the [[projects:crazyflie2:hardware:specification | full list of specifications]].
 ===== Using ===== ===== Using =====
-  * [[projects:crazyflie2:userguide:assembly|Assembly instructions]]: Image and video showing how to assemble your Crazyflie 2.0. Read this before you start assembly! +  * [[projects:crazyflie2:userguide:index|Userguide]]: User guide showing the different parts of your Crazyflie 2.X, what the LED indications mean and how to get started using it
-  * [[projects:crazyflie2:userguide:index|Userguide]]: User guide showing the different parts of your Crazyflie 2.0, what the LED indications mean and how to get started using it +  * [[projects:crazyflie2:userguide:serial|Crazyflie 2.serial]]: How to get the Crazyflie 2.serial on different platforms
-  * [[projects:crazyflie2:upgrading:index|Upgrading/flashing]]: How do upgrade/flash new firmware +
-  * [[projects:apps:ios:index|iOS userguide]]: Information and userguide for the iOS app used for flying from iPhone and iPad +
-  * [[doc:crazyflie:client:cfandroid:index|Android user guide]]: Information, userguide and list of compatible devices for the Android app used for flying +
-  * [[projects:crazyflie2:userguide:serial|Crazyflie 2.serial]]: How to get the Crazyflie 2.serial on different platforms +
-  * [[projects:crazyflie2:faq|FAQ]]: Frequently Asked Questions+
 ===== Development ===== ===== Development =====
-  *[[doc:crazyflie:dev:starting|Getting started developing]] +  *[[projects:crazyflie2:architecture:index|System architecture]]: Crazyflie 2.hardware and software system architecture
-  *[[projects:crazyflie2:architecture:index|System architecture]]: Crazyflie 2.hardware and software system architecture+
   *[[projects:crazyflie2:debugadapter:index|Debug adapter]]: How to solder the debug adapter kit   *[[projects:crazyflie2:debugadapter:index|Debug adapter]]: How to solder the debug adapter kit
   *[[projects:crazyflie2:development:dfu|DFU update of the STM32F405]]   *[[projects:crazyflie2:development:dfu|DFU update of the STM32F405]]
-  *[[projects:crazyflie2:development:ota|OTA (Over The Air) update of the STM32 using the Crazyradio/Crazyradio PA]] +
-===== Expansion decks ===== +
-  * [[projects:crazyflie2:expansionboards:index|Expansion board information]]: List of expansion boards and how they are used +
-  * [[projects:crazyflie2:expansionboards:ledring|LED-ring expansion deck]]: The LED-ring expansion deck +
-  * [[projects:crazyflie2:expansionboards:buzzer|Buzzer expansion deck]]: The Buzzer expansion deck +
-  * [[projects:crazyflie2:expansionboards:bigquad|BigQuad expansion deck]]: The BigQuad expansion deck +
-  * [[projects:crazyflie2:expansionboards:qi|Qi expansion deck]]: The Qi inductive charging expansion deck +
-  * [[projects:crazyflie2:expansionboards:proto|Prototype expansion deck]]: The prototype expansion deck +
-  * [[projects:crazyflie2:expansionboards:breakout|Breakout expansion deck]]: The breakout expansion deck +
-  * [[projects:crazyflie2:expansionboards:template|Expansion board template]]: The Crazyflie 2.0 expansion port template explained+
 ===== Electronics ===== ===== Electronics =====
-  * [[projects:crazyflie2:hardware:specification|Specification]]: The specification of the Crazyflie 2.0 hardware +  * [[projects:crazyflie2:hardware:schematics|CF 2.0 Schematics]]: Schematics of the Crazyflie 2.0
-  * [[projects:crazyflie2:hardware:schematics|Schematics]]: Schematics of the Crazyflie 2.0 +  * [[projects:crazyflie2:hardware:schematics21|CF 2.1 Schematics]]: Schematics of the Crazyflie 2.1
-  * [[projects:crazyflie2:hardware:spareparts|Spare components]]: A list of spare parts for the Crazyflie 2.0+  * [[projects:crazyflie2:hardware:spareparts|Spare components]]: A list of spare parts for the Crazyflie 2.
 +  * [[projects:crazyflie2:hardware:externalantenna|CF 2.1 external antenna]]: How to activate the Crazyflie 2.1 external antenna
projects/crazyflie2/index.txt · Last modified: 2020-05-12 14:56 by kimberly
