projects:crazyflie2:index [2017-01-25 12:54] tobias [Expansion decks] |
projects:crazyflie2:index [2020-05-12 14:56] (current) kimberly |
| - | ====== Crazyflie 2.0 ====== | + | <WRAP center round important 60%> |
| - | The Crazyflie 2.0 is a versatile flying development platform that weighs only 27g and fits in the palm of your hand. | + | This page has deprecated |
| - | Its advanced functionality makes it ideal for developers and its Bluetooth low energy (LE) capability makes it easy to fly from mobile devices. | + | [[https:// |
| - | With its small size and weight, it's ideal for indoor use, but can just as easily hover above your house as | + | </ |
| - | it can hover under your dining room table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled | + | |
| - | by simply attaching the motors to the circuit-board frame, then it's ready to fly. | + | |
| - | Before using the product please read the [[projects: | + | ====== Crazyflie 2.X ====== |
| - | **Features** | + | This page contains information about the hardware |
| - | * Durable | + | |
| - | * Easy assembly | + | For specifications of the platforms see below: |
| - | * Supports expansion decks with automatic detection | + | * [[https:// |
| - | * Supports flying from iOS and Android with Bluetooth LE support as well as from Windows/MacOSX/Linux with the Crazyradio or Crazyradio PA | + | * [[https:// |
| - | * Tested to above 1 km radio range line-of-sight (LOS) with Crazyradio PA | + | |
| - | * Wireless firmware update | + | Before using the product please read the [[projects: |
| - | * On-board charging via standard uUSB | + | |
| - | * Dual-MCU architecture with dedicated radio/power management SoC for advanced applications | + | |
| - | * Real-time logging, graphing, and setting of variables as well as full access to the available expansion decks with use of a Crazyradio or Crazyradio PA and a personal computer | + | |
| - | Have a look at the [[projects: | ||
| ===== Using ===== | ===== Using ===== | ||
| - | | + | * [[projects: |
| - | * [[projects: | + | |
| - | * [[doc: | + | |
| ===== Development ===== | ===== Development ===== | ||
| - | | + | *[[projects: |
| *[[projects: | *[[projects: | ||
| - | *[[projects: | + | |
| - | ===== Expansion decks ===== | + | |
| ===== Electronics ===== | ===== Electronics ===== | ||
| + | * [[projects: | ||
