User Tools
Site Tools
projects:crazyflie2:userguide:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:userguide:index [2014-09-24 14:43]
macke created
projects:crazyflie2:userguide:index [2020-05-12 13:58] (current)
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
 +</WRAP>
 ====== Detailed description of the hardware ====== ====== Detailed description of the hardware ======
 {{:projects:crazyflie2:userguide:legend_top.png|}} {{:projects:crazyflie2:userguide:legend_top.png|}}
Line 22: Line 27:
   - ** M3 connector **: Motor 3 connector   - ** M3 connector **: Motor 3 connector
   - ** M4 connector **: Motor 4 connector   - ** M4 connector **: Motor 4 connector
-  - ** STM32F405 debug connector **: Connector for debugging the STM32F405 using SWD. For easy access use our debug adapter kit. +  - ** STM32F405 debug connector **: Connector for debugging the STM32F405 using SWD. For easy access use our [[projects:crazyflie2:development:debug_adapter_kit|debug adapter kit]]
-  - ** nRF51822 debug pads **: Pads for debugging the nRF51822 using SWD. For easy access use our debug adapter kit.+  - ** nRF51822 debug pads **: Pads for debugging the nRF51822 using SWD. For easy access use our [[projects:crazyflie2:development:debug_adapter_kit|debug adapter kit]].
   - ** Expansion board orientation indicator **: This indicator should match the expansion boards   - ** Expansion board orientation indicator **: This indicator should match the expansion boards
   - ** STM32F405 micro controller **: The STM32F405 micro controller   - ** STM32F405 micro controller **: The STM32F405 micro controller
projects/crazyflie2/userguide/index.1411562619.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
