projects:crazyflie2:userguide:serial [2015-02-16 14:58] arnaud [Linux] |
projects:crazyflie2:userguide:serial [2020-05-12 14:23] (current) kimberly |
+ | ====== Getting the serial number of the Crazyflie 2.X ====== | ||
+ | The Crazyflie 2.X ID is a character string of 24 characters. It is unique to each Crazyflie 2.X. | ||
+ | ===== Windows ===== | ||
+ | * Open the " | ||
+ | * Right click on Crazyflie 2.0/2.1, go in " | ||
+ | * In the drop-box select " | ||
+ | The serial number is located just after " | ||
+ | By right-clicking on the string you can copy it. | ||
+ | ===== Linux ===== | ||
+ | Open a terminal and type (ie. cop-paste) the following command: | ||
+ | sudo lsusb -v -d 0483:5740 | grep iSerial | ||
+ | The Crazyflie serial is then displayed (here it starts by 41): | ||
+ | ===== Mac OS X ===== | ||
+ | From the "About this mac" menu, click on " | ||
+ | Then click on " | ||
