projects:crazyflie:binaries:raspberrypi [2015-03-23 10:55] arnaud [How do I get the RedOctane Xbox360 controller to work] |
projects:crazyflie:binaries:raspberrypi [2020-05-12 14:26] (current) kimberly |
| + | ====== Bitcraze Raspberry Pi SD-card image ====== | ||
| + | In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. The image is based on the [[http:// | ||
| + | We haven' | ||
| + | The changes made to the SD-card is mostly based of the contributed instructions from the [[misc: | ||
| + | ====== Download ====== | ||
| + | The SD-card image can be downloaded here (version 2015.3 and onward is compatible with Raspberrypi 2): | ||
| + | * Bitcraze Raspbian image 2015.3 ([[http:// | ||
| + | * Bitcraze Raspbian image 0.3 ([[http:// | ||
| + | * Bitcraze Raspbian image 0.2 ([[http:// | ||
| + | * Bitcraze Raspbian image 0.1 ([[http:// | ||
| + | <WRAP center round info > | ||
| + | Using Torrent is advised, we have added webseed so it is faster than direct download and guarantee the file integrity. | ||
| + | ====== Installing in an existing Raspbian sdcard ====== | ||
| + | If you already have a running raspbian system no need to download the image, connect your raspberrypi and run the following command to install all packages and dependencies. We are generating the official that way. You must be logged with the ' | ||
| + | curl https:// | ||
| + | ====== SD-image info ====== | ||
| + | Size: 4 GB | ||
| + | User: pi | ||
| + | Pass: raspberry | ||
| + | (version before 2015.3 had bitcraze/ | ||
| + | ====== What's added to the image ====== | ||
| + | There' | ||
| + | * UDEV rules for access to the Crazyradio and NRF bootloader | ||
| + | * crazyflie-pc-client pre-cloned at latest stable version | ||
| + | * pyusb | ||
| + | * UDEV rules to automatically launch the cfheadless client when Crazyradio is plugged in | ||
| + | * Driver for the Xbox 360 wireless controller and automatic start of the utilities | ||
| + | ====== Creating the SD-card ====== | ||
| + | First of all you have to write the image to the SD-card. There are good instructions on how to do this [[http:// | ||
| + | ====== How to use the SD-card image ====== | ||
| + | First of all you need to set up what controller and link settings you are using. This is done by editing the two files in the folder /home/pi named controller.conf and link.conf. They should only contain one row each. | ||
| + | To fly first insert the USB controller, then power on the Crazyflie and lastly insert the Crazyradio. This will start the cfheadless client and connect to the Crazyflie. In a few seconds you should be ready to fly. | ||
| + | To quit either power off the Crazyflie or pull-out the Crazyradio. | ||
| + | In order to restart flying you have to pull-out the Crazyradio dongle and insert it again. | ||
| + | ====== Troubleshooting ====== | ||
| + | Try to pull-out and insert the Crazyradio. Then wait up to 10 seconds before you try to control the Crazyflie. | ||
| + | If you see the LED on the Crazyradio blinking green, then it's connected. If it's blinking red it means that it cannot connect to the Crazyflie. | ||
| + | Check logfile / | ||
| + | ====== FAQ ====== | ||
| + | ===== How do I get the RedOctane Xbox360 controller to work ===== | ||
| + | You will have to edit the ''/ | ||
| + | #!/bin/sh | ||
| + | if test " | ||
| + | then | ||
| + | else | ||
| + | killall -9 xboxdrv | ||
| + | fi | ||
| + | {{tag> | ||
