projects:crazyflie:binaries:raspberrypi [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyflie:binaries:raspberrypi [2020-05-12 14:26] (current) kimberly |
| ====== Bitcraze Raspberry Pi SD-card image ====== | ====== Bitcraze Raspberry Pi SD-card image ====== | ||
| In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. The image is based on the [[http:// | In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. The image is based on the [[http:// | ||
