projects:crazyflie:devenv:index [2012-03-11 10:06] arnaud |
projects:crazyflie:devenv:index [2014-12-16 00:11] chad Added a Setup on Mac OS X section with a link to a post about the Mac OS X dev environment. |
- | ====== Development environment ====== | ||
- | ===== Software Tools ===== | ||
- | ==== Software used ==== | ||
- | The following software is in the Crazyflie development environment toolchain: | ||
- | * [[http:// | ||
- | These are available for both Windows and Linux. | ||
- | ==== Setup on Fedora 16 ==== | ||
- | === Installing === | ||
- | === Fix permissions === | ||
- | In order to fix the permissions so it's possible to use the JTAG and USB Radio without being root do the following steps. | ||
- | sudo usermod -a -G plugdev username | ||
- | Note that you will need to logout and in again for the added group to take effect. | ||
- | Find the JTAG vendor/ | ||
- | Create a file named / | ||
- | SUBSYSTEM==" | ||
- | ==== Setup on Windows ==== | ||
- | ===== Compiling the copter code ===== | ||
- | The Crazyflie project is based on a Makefile. A couple of target are useful: | ||
- | <code bash> | ||
- | $ make # Make copter firmware | ||
- | $ make V=1 # Make copter firmware and shows the full compilation commands | ||
- | $ make CLOAD=1 # make copter firmware to be used with the bootloader | ||
- | $ make flash # Flash firmware using openOCD and the jtagKey | ||
- | $ make reset # Reset the copter using openOCD | ||
- | $ make openocd # Launch openOCD and connect it to the copter (can then be used via the telnet interface and/or GDB) | ||
- | It must be noted that the openOCD targets do not make the copter code, hence the compilation must be called first with '' | ||
