projects:crazyflie:devenv:index [2014-12-16 00:11] chad Added a Setup on Mac OS X section with a link to a post about the Mac OS X dev environment. |
projects:crazyflie:devenv:index [2021-06-24 16:47] kimberly |
+ | ====== Development environment ====== | ||
+ | ===== Software Tools ===== | ||
+ | ==== Software used ==== | ||
+ | The following software are used by the Crazyflie development environment toolchain: | ||
+ | * [[https:// | ||
+ | GNU Tools for ARM Embedded Processors]] | ||
+ | * [[http:// | ||
+ | These are available for both Windows and Linux. | ||
+ | ==== Setup on Fedora 16 ==== | ||
+ | === Installing === | ||
+ | In order to fix the permissions so it's possible to use the JTAG and USB Radio without being root do the following steps. | ||
+ | sudo usermod -a -G plugdev username | ||
+ | Note that you will need to logout and in again for the added group to take effect. | ||
+ | Find the JTAG vendor/ | ||
+ | Create a file named / | ||
+ | SUBSYSTEM==" | ||
+ | ==== Setup on Ubuntu 13.04 ==== | ||
+ | wget https:// | ||
+ | mkdir ~/bin | ||
+ | And then also add the binaries to your path: | ||
+ | echo -e " | ||
+ | source ~/.bashrc | ||
+ | ==== Setup on Windows ==== | ||
+ | TBD | ||
+ | ==== Setup on Mac OS X ==== | ||
+ | Development environment setup is relatively easy on Mac OS X. | ||
+ | [[http:// | ||
+ | ===== Compiling the copter code ===== | ||
+ | The Crazyflie project is based on a Makefile. A couple of target are useful: | ||
+ | <code bash> | ||
+ | crazyflie-fimrware$ make # Make copter firmware | ||
+ | crazyflie-fimrware$ make V=1 # Make copter firmware and shows the full compilation commands | ||
+ | crazyflie-fimrware$ make CLOAD=1 # Make copter firmware to be used with the bootloader | ||
+ | crazyflie-fimrware$ make clean && make USE_ESKYLINK=1 CLOAD=1 all # Make copter firmware to be used with the bootloader, CF controlled with eSky ET6i transmitter | ||
+ | crazyflie-fimrware$ make cload # Flash the firmware using the radio bootloader | ||
+ | crazyflie-fimrware$ make flash # Flash firmware using openOCD and the jtagKey | ||
+ | crazyflie-fimrware$ make reset # Reset the copter using openOCD | ||
+ | A couple of variables can be set on the command line or shell environment to configure the build process: | ||
+ | ^ Variable ^ Default value ^ Usage ^ | ||
+ | | CLOAD | 1 | If at 1 the firmware is liked to be used with the bootloader. | ||
+ | | DEBUG | 0 | If at 1 the firmware will be build without optimization and with debug symbol (the firmware is ~70K in debug mode and ~40K optimized). | | ||
+ | | CROSS_COMPILE | | ||
+ | | OPENOCD_INTERFACE | | ||
+ | | V | 0 | Verbose mode. If V=1 the compilers command lines will be displayed. If V=0 only the tool type and target file are displayed. | | ||
+ | | PYTHON2 | python | ||
+ | | USE_ESKYLINK| | ||
+ | It is possible to create a file // | ||
+ | The openOCD targets do not make the copter code, hence the compilation must be called first with '' | ||
+ | It is possible to flash with openOCD/ | ||
+ | It is also possible to work with the copter code from within Eclipse. | ||
+ | ===== Compiling and flashing the bootloader ===== | ||
+ | The copter can be loaded with a radio bootloader contained in the crazyloader folder. The dev environment is very similar to the copter one: | ||
+ | crazyflie-bootloader$ make # Make the bootoader | ||
+ | crazyflie-bootloader$ make flash # Flash the bootloader with openOCD | ||
