projects:crazyflie:faq [2013-02-01 15:23] tobias |
projects:crazyflie:faq [2013-04-22 13:50] tobias [Can't I use a normal R/C transmitter] |
Line 24: | Line 24: | ||
==== Can't I use a normal R/C transmitter ==== | ==== Can't I use a normal R/C transmitter ==== | ||
- | The e-sky R/C transmitters use the nRF24L01 chip, compatible with ours, so it would be possible to control the Crazyflie using the e-sky transmitters. | + | The e-sky R/C transmitters use the nRF24L01 chip, compatible with ours, so it would be possible to control the Crazyflie using the e-sky transmitters. |
==== How durable is the Crazyflie ==== | ==== How durable is the Crazyflie ==== |
