projects:crazyflie:faq [2013-05-20 08:45] arnaud [Can't I use a normal R/C transmitter] |
projects:crazyflie:faq [2013-05-21 09:52] tobias [Can't I use a normal R/C transmitter] |
Line 24: | Line 24: | ||
==== Can't I use a normal R/C transmitter ==== | ==== Can't I use a normal R/C transmitter ==== | ||
- | The e-sky R/C transmitters use the nRF24L01 chip, compatible with ours, so is be possible to control the Crazyflie using the e-sky transmitters. Firmware support is in beta stage. Also see "Is a PC required for the Crazyradio" | + | The e-sky R/C transmitters use the nRF24L01 chip, compatible with ours, so it is possible to control the Crazyflie using the e-sky transmitters. Firmware support is in beta stage. Also see "Is a PC required for the Crazyradio" |
==== How durable is the Crazyflie ==== | ==== How durable is the Crazyflie ==== |
