projects:crazyflie:faq [2013-10-20 17:55] fred [Can the Crazyflie be used to control a bigger quadcopter?] |
projects:crazyflie:faq [2013-10-20 17:57] fred [Is a PC required for the Crazyradio?] |
Line 21: | Line 21: | ||
- | * It can be connected to an Android device with USB host functionality. We are currently working on an android | + | * It can be connected to an Android device with USB host functionality. |
+ | * We are currently working on an Android | ||
+ | * [[projects: | ||
==== Can't I use a normal R/C transmitter? | ==== Can't I use a normal R/C transmitter? |
