projects:crazyflie:faq [2013-10-20 17:55] fred [Can the Crazyflie be used to control a bigger quadcopter?] |
projects:crazyflie:faq [2013-10-20 18:13] fred [Can the Crazyflie fly autonomously (aka. autopilot)?] |
Line 21: | Line 21: | ||
- | * It can be connected to an Android device with USB host functionality. We are currently working on an android | + | * It can be connected to an Android device with USB host functionality. |
+ | * We are currently working on an Android | ||
+ | * [[projects: | ||
==== Can't I use a normal R/C transmitter? | ==== Can't I use a normal R/C transmitter? | ||
Line 32: | Line 34: | ||
Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi... | Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi... | ||
- | ==== Can the Crazyflie fly autonomously? | + | ==== Can the Crazyflie fly autonomously |
Not yet, but there is ongoing development in this area: | Not yet, but there is ongoing development in this area: | ||
* using onboard sensors (e.g. the barometer in the 10-DOF version) to achieve a "hover mode": http:// | * using onboard sensors (e.g. the barometer in the 10-DOF version) to achieve a "hover mode": http:// | ||
* using extra sensors (e.g. an ultra sonic sensor): http:// | * using extra sensors (e.g. an ultra sonic sensor): http:// | ||
* using external sensors (Camera, Kinect, etc.) | * using external sensors (Camera, Kinect, etc.) | ||
- | * First test with OpenCV: | + | * [[http:// |
- | * Kinect: | + | * [[http:// |
+ | * [[http:// | ||
==== How can I build an autonomous swarm of Crazyflies? ==== | ==== How can I build an autonomous swarm of Crazyflies? ==== | ||
Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) | Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) | ||
+ | ==== Can I do FPV (first person view) flying with a Crazyflie? ==== | ||
+ | There is ongoing development in this area: | ||
+ | * [[http:// |
