projects:crazyflie:faq [2013-10-20 17:57] fred [Is a PC required for the Crazyradio?] |
projects:crazyflie:faq [2015-07-15 16:31] 127.0.0.1 external edit |
Line 21: | Line 21: | ||
+ | * It can be used in " | ||
* It can be connected to an Android device with USB host functionality. | * It can be connected to an Android device with USB host functionality. | ||
- | * We are currently working on an Android client which is in beta stage. [[https://bitbucket.org/ | + | * We are currently working on an Android client which is in beta stage. [[https://github.com/ |
- | * [[projects:crazyflie:android_client:user_guide|Android client user guide]] | + | * [[doc:crazyflie:client:cfandroid: |
==== Can't I use a normal R/C transmitter? | ==== Can't I use a normal R/C transmitter? | ||
Line 34: | Line 36: | ||
Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi... | Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi... | ||
- | ==== Can the Crazyflie fly autonomously? | + | First steps towards a bigger Crazyflie: |
+ | * [[http:// | ||
+ | ==== Can the Crazyflie fly autonomously | ||
Not yet, but there is ongoing development in this area: | Not yet, but there is ongoing development in this area: | ||
* using onboard sensors (e.g. the barometer in the 10-DOF version) to achieve a "hover mode": http:// | * using onboard sensors (e.g. the barometer in the 10-DOF version) to achieve a "hover mode": http:// | ||
* using extra sensors (e.g. an ultra sonic sensor): http:// | * using extra sensors (e.g. an ultra sonic sensor): http:// | ||
* using external sensors (Camera, Kinect, etc.) | * using external sensors (Camera, Kinect, etc.) | ||
- | * First test with OpenCV: | + | * [[http:// |
- | * Kinect: | + | * [[http:// |
==== How can I build an autonomous swarm of Crazyflies? ==== | ==== How can I build an autonomous swarm of Crazyflies? ==== | ||
- | Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) | + | * Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) |
+ | * Not yet a swarm, but at least two Crazyflies flying next to each other -> [[https:// | ||
+ | ==== Can I do FPV (first person view) flying with a Crazyflie? ==== | ||
+ | There is ongoing development in this area: | ||
+ | * [[http:// |
