projects:crazyflie:faq [2013-10-20 18:00] fred [Can the Crazyflie fly autonomously?] |
projects:crazyflie:faq [2014-05-23 00:48] fred [Is a PC required for the Crazyradio?] |
Line 21: | Line 21: | ||
+ | * It can be used in " | ||
* It can be connected to an Android device with USB host functionality. | * It can be connected to an Android device with USB host functionality. | ||
- | * We are currently working on an Android client which is in beta stage. [[https://bitbucket.org/ | + | * We are currently working on an Android client which is in beta stage. [[https://github.com/ |
==== Can't I use a normal R/C transmitter? | ==== Can't I use a normal R/C transmitter? | ||
Line 39: | Line 41: | ||
* using extra sensors (e.g. an ultra sonic sensor): http:// | * using extra sensors (e.g. an ultra sonic sensor): http:// | ||
* using external sensors (Camera, Kinect, etc.) | * using external sensors (Camera, Kinect, etc.) | ||
- | * First test with OpenCV: | + | * [[http:// |
- | * Kinect: | + | * [[http:// |
- | * Autopilot discussion: | + | * [[http:// |
==== How can I build an autonomous swarm of Crazyflies? ==== | ==== How can I build an autonomous swarm of Crazyflies? ==== | ||
Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) | Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) | ||
+ | ==== Can I do FPV (first person view) flying with a Crazyflie? ==== | ||
+ | There is ongoing development in this area: | ||
+ | * [[http:// | ||
+ | * [[http:// |
