projects:crazyflie:faq [2013-10-20 18:13] fred [Can the Crazyflie fly autonomously (aka. autopilot)?] |
projects:crazyflie:faq [2015-07-15 16:31] 127.0.0.1 external edit |
Line 21: | Line 21: | ||
+ | * It can be used in " | ||
* It can be connected to an Android device with USB host functionality. | * It can be connected to an Android device with USB host functionality. | ||
- | * We are currently working on an Android client which is in beta stage. [[https://bitbucket.org/ | + | * We are currently working on an Android client which is in beta stage. [[https://github.com/ |
- | * [[projects:crazyflie:android_client:user_guide|Android client user guide]] | + | * [[doc:crazyflie:client:cfandroid: |
==== Can't I use a normal R/C transmitter? | ==== Can't I use a normal R/C transmitter? | ||
Line 33: | Line 35: | ||
==== Can the Crazyflie be used to control a bigger quadcopter? ==== | ==== Can the Crazyflie be used to control a bigger quadcopter? ==== | ||
Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi... | Yes, it could. All the key components are there to control a quadcopter of any size. There is yet no firmware support for this though. However, imagine having it dockable into a big frame which could carry it a long way and then just release it so it can enter a small area where the big frame can't get to, Sci-Fi... | ||
+ | First steps towards a bigger Crazyflie: | ||
+ | * [[http:// | ||
==== Can the Crazyflie fly autonomously (aka. autopilot)? ==== | ==== Can the Crazyflie fly autonomously (aka. autopilot)? ==== | ||
Line 43: | Line 49: | ||
* [[http:// | * [[http:// | ||
==== How can I build an autonomous swarm of Crazyflies? ==== | ==== How can I build an autonomous swarm of Crazyflies? ==== | ||
- | Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) | + | * Before dealing with an autonomous swarm, maybe deal with one autonomous Crazyflie first. ;) |
+ | * Not yet a swarm, but at least two Crazyflies flying next to each other -> [[https:// | ||
==== Can I do FPV (first person view) flying with a Crazyflie? ==== | ==== Can I do FPV (first person view) flying with a Crazyflie? ==== |
