projects:crazyflie:firmware:comm_protocol [2013-04-02 15:14] arnaud [Serial port] |
projects:crazyflie:firmware:comm_protocol [2013-10-02 12:57] ledvinap [Logging] |
Line 21: | Line 21: | ||
^ **Link** | ^ **Link** | ||
Line 28: | Line 28: | ||
Line 47: | Line 47: | ||
| DATA 30 | | | DATA 30 | | ||
- | | 0xAA | 0xAA | Header | Length | Data0 | Packet | CRC32 | | ||
Line 65: | Line 61: | ||
Line 71: | Line 67: | ||
==== Serial port ==== | ==== Serial port ==== | ||
7 | 7 | ||
Line 105: | Line 103: | ||
+ | === Examples === | ||
+ | To send setpoints to the [[projects: | ||
+ | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
+ | To ping Crazyflie: | ||
===== Ports ===== | ===== Ports ===== | ||
Line 115: | Line 124: | ||
Line 121: | Line 130: | ||
Line 157: | Line 167: | ||
- | with ID omitted | + | |
+ | [optional] | ||
+ | (or any higher) | ||
Line 174: | Line 190: | ||
+ | | Reset log | ||
^ **Byte** | ^ **Byte** | ||
Line 198: | Line 217: | ||
Line 209: | Line 229: | ||
Line 219: | Line 239: | ||
7 | 7 | ||
Line 228: | Line 249: | ||
7 | 7 | ||
+ | | 0xff | | ||
Line 244: | Line 268: | ||
- | | 0x00 | + | | |
- | | 0x01 | + | | |
- | | 0xFF | + | | |
[DONE] | [DONE] | ||
Line 278: | Line 303: | ||
+ | ^ **Byte** | ||
The parameters system aims at making accessible all the gettable and settable parameters of the copter. In the copter a table of parameters is hold and can be retrieved. In this table every parameter name is associated with an ID and a group name. Three ID are used to acces the TOC and the paramareters: | The parameters system aims at making accessible all the gettable and settable parameters of the copter. In the copter a table of parameters is hold and can be retrieved. In this table every parameter name is associated with an ID and a group name. Three ID are used to acces the TOC and the paramareters: |
