projects:crazyflie:firmware:comm_protocol [2013-04-02 15:43] arnaud [Packet structure] |
projects:crazyflie:firmware:comm_protocol [2014-05-09 04:21] fred [Logging] fixed tiny but significant typo in hex string that cost me an hour of debugging |
Line 21: | Line 21: | ||
^ **Link** | ^ **Link** | ||
Line 28: | Line 28: | ||
Line 61: | Line 61: | ||
Line 103: | Line 103: | ||
+ | === Examples === | ||
+ | To send setpoints to the [[projects: | ||
+ | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
+ | To ping Crazyflie: | ||
===== Ports ===== | ===== Ports ===== | ||
Line 113: | Line 124: | ||
Line 119: | Line 130: | ||
Line 155: | Line 167: | ||
- | with ID omitted | + | |
+ | [optional] | ||
+ | (or any higher) | ||
Line 172: | Line 190: | ||
+ | | Reset log | ||
^ **Byte** | ^ **Byte** | ||
Line 196: | Line 217: | ||
Line 207: | Line 229: | ||
Line 217: | Line 239: | ||
7 | 7 | ||
Line 226: | Line 249: | ||
7 | 7 | ||
+ | | 0xff | | ||
Line 242: | Line 268: | ||
- | | 0x00 | + | | |
- | | 0x01 | + | | |
- | | 0xFF | + | | |
[DONE] | [DONE] | ||
Line 276: | Line 303: | ||
+ | ^ **Byte** | ||
The parameters system aims at making accessible all the gettable and settable parameters of the copter. In the copter a table of parameters is hold and can be retrieved. In this table every parameter name is associated with an ID and a group name. Three ID are used to acces the TOC and the paramareters: | The parameters system aims at making accessible all the gettable and settable parameters of the copter. In the copter a table of parameters is hold and can be retrieved. In this table every parameter name is associated with an ID and a group name. Three ID are used to acces the TOC and the paramareters: |
