projects:crazyflie:firmware:comm_protocol [2013-10-02 12:57] ledvinap [Logging] |
projects:crazyflie:firmware:comm_protocol [2014-05-23 01:39] fred [Parameters] |
Line 320: | Line 320: | ||
Receiving a log block 0xbb with timestamp 130.532s (0x1FDE4 ms), logging uint16 variable with value 0xBABE: | Receiving a log block 0xbb with timestamp 130.532s (0x1FDE4 ms), logging uint16 variable with value 0xBABE: | ||
- | CF -> Computer : 0x[5,2] 0xBB 0xE4 0xDF 0x01 0xBE 0xBA | + | CF -> Computer : 0x[5,2] 0xBB 0xE4 0xFD 0x01 0xBE 0xBA |
Line 352: | Line 352: | ||
- | **TODO** | + | |
- | **TODO** | + | ^ |
+ | | Parameter read | | ||
