projects:crazyflie:firmware:comm_protocol [2014-05-09 04:21] fred [Logging] fixed tiny but significant typo in hex string that cost me an hour of debugging |
projects:crazyflie:firmware:comm_protocol [2014-05-23 01:39] fred [Parameters] |
Line 323: | Line 323: | ||
Line 352: | Line 352: | ||
- | **TODO** | + | |
- | **TODO** | + | ^ |
+ | | Parameter read | | ||
