projects:crazyflie:firmware:comm_protocol [2012-07-30 15:06] macke created |
| ====== Overview ====== | ====== Overview ====== | ||
| - | ===== CRTP? ===== | + | CRTP is the protocol used to communicate |
| - | The CRTP (Crazy RealTime Protocol) | + | |
| - | * UART | + | CRTP is implemented in 3 layers: |
| - | * USB | + | |
| - | * [[projects: | + | < |
| + | | CRTP packets handling | | ||
| + | * **CRTP Link** is responsible for transferring the packets between the copter and the PC. It will typically handles packet size and error detection. | ||
| + | * **CRTP Packet handling** delivers the packet to the right subsystem in the copter and in the PC control software. | ||
| + | * **Application/ | ||
| + | Implemented link drivers: | ||
| + | ^ **Link** | ||
| + | | [[comm_protocol# | ||
| + | Current port allocation: | ||
| + | ^ **Port** | ||
| + | | 2 | ||
| ====== Communication ====== | ====== Communication ====== | ||
| ===== Packet structure ===== | ===== Packet structure ===== | ||
| - | The CRTP packet consists of 32 bytes of data: | + | A CRTP packet consists of a 8bit header followed by 0-31 bytes of data. |
| - | | PORT | DATA | | + | |
| - | | PORT | <31 | | + | |
| - | 1 | + | |
| - | The ports numbers are composed of: Priority, task number and message number. | + | |
| - | * The priority is set by the 2 MSB of the port number. It permit to each task to chose in a per message basis the priority of its messages | + | |
| - | * The task number is used by CRTP to distribute the messages to the different tasks in the copter | + | |
| - | * Finally the message number is composed by the two LSB and permit to have 4 different communication channel per task. | + | |
| - | A proposed notation is P:T:N, P is the priority, T is the task number and N the message number. The port number is then built as follow: | + | |
| + | 7 | ||
| - | | P | + | | Port |
| + | | DATA 0 | | ||
| + | | DATA 30 | ||
| - | #define PORT(P,T,N) ((P<< | ||
| - | ''' | + | ^ **Field** ^ **Byte** ^ **Bit** ^ |
| + | | Data | ||
| + | A port maps to a major function in the Crazyflie that is normally implemented as a separate task. When a CRTP packet is received in the Crazyflie the packet | ||
| ===== Physical layers ===== | ===== Physical layers ===== | ||
| Below is the structures for the packages both for the wired serial interface and for the wireless interface. The limitation for the length of the data is set so that it will fit inside one packet for the wireless transmission. | Below is the structures for the packages both for the wired serial interface and for the wireless interface. The limitation for the length of the data is set so that it will fit inside one packet for the wireless transmission. | ||
| + | ==== 2.4 GHz NordicSemi Radio ==== | ||
| + | The wireless interface will add additional header data like CRC when sending the packet and therefore the packet sent to the wireless interface is only a CRTP packet (header and data). | ||
| + | ==== USB port ==== | ||
| + | **TODO** | ||
| ==== Serial port ==== | ==== Serial port ==== | ||
| + | The serial port is configured in 115200 8N1. CRTP packets are sent and received asynchronously using the following packet format: | ||
| - | Serial port: | + | 7 |
| - | | START | PORT | LENGTH | + | | |
| - | | 0xAAAA| PORT | < | + | | 0xAA |
| + | | DATA 0 | | ||
| + | | DATA 30 | ||
| + | | Cksum | ||
| + | | 0xAA | 0xAA | Header | Length | Data0 | Packet | Cksum | | ||
| - | ==== 2.4 GHz NordicSemi Radio ==== # | ||
| - | Wireless: | ||
| - | | PORT | DATA | | ||
| - | | PORT | <31 | | ||
| - | 1 | ||
| - | The wireless firmware adds ADDRESS, PID, LENGTH and CRC automatically. | ||
| + | ^ **Field** ^ **Byte** ^ **Bit** ^ | ||
| + | | Size | ||
| + | | Data | ||
| + | === Examples === | ||
| + | To send setpoints to the [[projects: | ||
| + | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
| + | To ping Crazyflie: | ||
| ===== Ports ===== | ===== Ports ===== | ||
| - | | *Port* | + | |
| - | | [[CommunicationProtocol#console|000]] | Console | + | ==== Logging ==== |
| - | | [[CommunicationProtocol#acc|*1*]] | Acc Log | + | The purpose of the logging is to be able to log variables that are available in the copter during runtime. The available variables are listed using a TOC that can be read from the copter. A logging block can then be registered consisting of there variables and the data will be sent periodically via CRTP to a receiver. |
| - | | [[CommunicationProtocol#gyro|*2*]] | Gyro Log | | + | |
| - | | [[CommunicationProtocol# | + | ^ **Port** |
| - | | [[CommunicationProtocol# | + | | |
| - | | [[CommunicationProtocol#multilog|*5*]] | MultiLog 2 | | + | | |
| - | | [[CommunicationProtocol#pid|*6*]] | + | | |
| - | | [[CommunicationProtocol#information|*8*]] | Copter information | + | === Table of content access (Port 5 channel 0) === |
| - | | [[CommunicationProtocol# | + | This channel is used to access the loggable variables table of content. |
| - | | 0:13:0 | Send/ | + | == Messages == |
| - | | [[CommunicationProtocol# | + | Each message uses an additional command byte that is followed by 0 to 31 bytes of data depending of the command. For every command byte there' |
| + | The logging variables are requested by the receiver until all variables are returned. When the variable index is out of range, empty reply is returned (1 byte reply with 0x00 identifying the command). The Get CRC command returns the number of loggable variables N, individual variables are indexed from 0 to N-1. | ||
| + | The CRC32 is a hash of the copter' | ||
| + | The following messages are sent from the Client to the Crazyflie: | ||
| + | ^ **Request for** ^ **Byte** | ||
| + | | TOC item | | ||
| + | | TOC CRC and count | 0 | 0x01 (CMD_GET_INFO) Request the TOC CRC and item count | | ||
| + | The following messages are sent from the Crazyflie to the Client: | ||
| + | | TOC item | ||
| + | | ::: | 1 | ||
| + | | TOC CRC and count | | ||
| + | == Usage == | ||
| + | Example of checking the CRC of a TOC to determine if the TOC needs to be refreshed. | ||
| + | Get TOC CRC32 ---> | ||
| + | [Compare CRC] | ||
| + | Example of downloading TOC contents from Crazyflie. | ||
| + | Request for TOC item 0 | ||
| + | Request for TOC item 1 | ||
| + | Request for TOC item N-1 ---> | ||
| + | where N is Number of | ||
| + | total variables in TOC | ||
| + | [optional] | ||
| + | Request for TOC item N | ||
| + | (or any higher) | ||
| + | [Fetch complete] | ||
| + | === Log settings access (Port 5 channel 1) === | ||
| + | This channel is used to access the log settings to add/ | ||
| + | == Messages == | ||
| + | | ::: | 1 | Desired block id | ||
| + | | ::: | 2-31 | ||
| + | | Append to existing log block | ||
| + | | Delete a log block | ||
| + | | Start a log block | ||
| + | | Stop a log block | ||
| + | | Reset log | ||
| + | The response for all of the above messages is sent from the Crazyflie to the Client: | ||
| + | | 2 | Return status for the command. If != 0 see [[comm_protocol#list_of_return_codes|list of return codes ]] | | ||
| + | == Variable format == | ||
| + | The following format is used to identify a variable that is to be logged from the Crazyflie | ||
| + | Log Type represents type of value sent in packet. Logged value is converted to this type before storing into log packet. Upper bytes will be discarded if Log Type is integer and value does not fit. | ||
| + | | 8 | float16 | ||
| + | | 0 | Variable in TOC | ||
| + | | 1 | ||
| + | TOC variable request (Storage type is ignored, it is taken from Crazyflie internal TOC): | ||
| + | 7 | ||
| + | | Storage type | Log type | | ||
| + | | Variable ID | | ||
| + | Arbitrary memory address request: | ||
| + | 7 | ||
| + | | 0xff | | ||
| + | | Mem Address 0 | | ||
| + | | Mem Address 1 | | ||
| + | | Mem Address 2 | | ||
| + | | Mem Address 3 | | ||
| + | == List of return codes ( errno.h codes are used, returned values are positive ) == | ||
| + | | 0 | No error | | ||
| + | | ENOENT (2) | Block or variable not found | | ||
| + | | E2BIG (7) | Log block is too long | | ||
| + | | ENOEXEC (8) | Unknown command received | ||
| + | | ENOMEM (12) | No memory to allocate Log Block or Log Item | | ||
| + | Adding a new log block with id 0x0a with variable 0x55 type uint32_t and variable 0x66 type float32 to the settings: | ||
| + | Add log block ---> | ||
| + | [DONE] | ||
| + | Packet structure: | ||
| + | Computer -> CF : 0x[5,1] 0x00 0x0a 0x03 0x55 0x07 0x66 | ||
| + | CF -> Computer : 0x[5,1] 0x00 0x0a 0x00 | ||
| + | Deleting an existing log block 0x55 from the settings: | ||
| + | Delete log packet | ||
| + | [DONE] | ||
| + | Computer -> CF : 0x[5,1] 0x02 0x55 | ||
| + | CF -> Computer : 0x[5,1] 0x02 0x55 0x00 | ||
| + | === Log data access (Port 5 channel 2) === | ||
| + | Logging data is sent back to the copter as raw data with only the block id. This means that the lookup of what data is for what variable has to be done on the computer side. Log | ||
| + | block header contains 3 byte timestamp, its value is number of microseconds from Crazyflie system start (it will wrap around in about 16 seconds. Is is also currently based on xTaskGetTickCount, | ||
| + | ^ **Byte** | ||
| + | | 4-31 | Logged variable values, LSB first | | ||
| + | Adding a log block 0xbb at 100ms interval logging variable ID 0x55 of type uint16: | ||
| + | Computer -> CF : 0x[5,1] 0x00 0xbb 0x02 0x55 // create logging block | ||
| + | CF -> Computer : 0x[5,1] 0x00 0x55 0x00 // OK | ||
| + | Computer -> CF : 0x[5,1] 0x03 0xbb 0x0A // start sending block with 100ms interval | ||
| + | CF -> Computer : 0x[5,1] 0x03 0x55 0x00 // OK | ||
| + | Receiving a log block 0xbb with timestamp 130.532s (0x1FDE4 ms), logging uint16 variable with value 0xBABE: | ||
| + | CF -> Computer : 0x[5,2] 0xBB 0xE4 0xFD 0x01 0xBE 0xBA | ||
| + | ==== Parameters ==== | ||
| + | The parameters system makes all the gettable and settable parameters of the copter accessible. The copter holds a table of parameters which can be retrieved. In this table every parameter name is associated with an ID and a group name. Three IDs are used to acces the TOC and the parameters: | ||
| + | ^ Port ^ Channel | ||
| + | | 2 | 2 | Parameter write | | ||
| + | === TOC access (Port 2 channel | ||
| + | These messages permit to access the parameters table of content. The first byte of the message is a message ID, three messages ID are defined: | ||
| + | ^ Message ID ^ Meaning in upstream packets | ||
| + | | 1 | Get next TOC element | ||
| + | | 3 | Get TOC CRC32 | Number of parameters, TOC CRC32 | | ||
| + | The upstream ID are commands | ||
| + | Bytes | ||
| + | | 0 | | | | | ||
| + | | 1 | | | | | | ||
| + | | 3 | Num. Param | CRC32 | | ||
| + | Bytes | ||
| + | The parameters are sequentially requested by the PC until the end. When the last parameter is reached it has the ID 0 'Last TOC element' | ||
| + | The CRC32 is a hash of the copter TOC. This is aimed at implementing caching of the TOC in the PC Utils to avoid fetching the full TOC each time the copter is connected. | ||
| + | === Parameter read (Port 2 channel 1) and parameter write (Port 2 channel 2)=== | ||
| + | The following messages are sent from the client to the Crazyflie: | ||
| + | | Parameter write | ||
| + | The following messages are sent from the Crazyflie to the client: | ||
| + | ^ **Reply for** ^ **Byte** | ||
| + | | Parameter read & write | ||
| + | === Fight control ==== | ||
| + | **TODO** | ||
| + | === Link layer === | ||
| | 3: | | 3: | ||
| | 3: | | 3: | ||
| | 3: | | 3: | ||
| | 3: | | 3: | ||
| - | ==== Console ==== | ||
| - | This port is used as a simulation of the text based console. The idea is to map putc/getc there (and, by extention, it should be the target of printf). | ||
| - | The packet format contains only the datas to send/ | ||
| - | <pre> | ||
| - | | Data | | ||
| - | From the copter side a _fair_ behavior should be to have a buffer and to send a new packet if at least one of the 3 following condition is fullfil: | ||
| - | * The output buffer (of 31bytes) is full | ||
| - | * A " | ||
| - | * A flush command as been issued | ||
