projects:crazyflie:firmware:comm_protocol [2013-01-15 11:31] macke |
projects:crazyflie:firmware:comm_protocol [2021-06-24 16:49] kimberly |
CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | ||
Line 21: | Line 24: | ||
^ **Link** | ^ **Link** | ||
Line 28: | Line 31: | ||
Line 47: | Line 50: | ||
| DATA 30 | | | DATA 30 | | ||
- | | 0xAA | 0xAA | Header | Length | Data0 | Packet | CRC32 | | ||
Line 65: | Line 64: | ||
Line 71: | Line 70: | ||
==== Serial port ==== | ==== Serial port ==== | ||
7 | 7 | ||
Line 78: | Line 79: | ||
- | | R | | + | | |
Line 88: | Line 89: | ||
Line 98: | Line 99: | ||
^ **Field** ^ **Byte** ^ **Bit** ^ | ^ **Field** ^ **Byte** ^ **Bit** ^ | ||
- | | Size | + | | Size |
- | | Data | + | | Data |
- | | | + | | Cksum | |
+ | === Examples === | ||
+ | To send setpoints to the [[projects: | ||
+ | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
+ | To ping Crazyflie: | ||
===== Ports ===== | ===== Ports ===== | ||
Line 115: | Line 127: | ||
Line 121: | Line 133: | ||
Line 157: | Line 170: | ||
- | with ID omitted | + | |
+ | [optional] | ||
+ | (or any higher) | ||
Line 174: | Line 193: | ||
+ | | Reset log | ||
^ **Byte** | ^ **Byte** | ||
Line 198: | Line 220: | ||
Line 209: | Line 232: | ||
Line 219: | Line 242: | ||
7 | 7 | ||
Line 228: | Line 252: | ||
7 | 7 | ||
+ | | 0xff | | ||
Line 244: | Line 271: | ||
- | | 0x00 | + | | |
- | | 0x01 | + | | |
- | | 0xFF | + | | |
[DONE] | [DONE] | ||
Line 278: | Line 306: | ||
+ | ^ **Byte** | ||
Line 320: | Line 355: | ||
- | **TODO** | + | |
- | **TODO** | + | ^ |
+ | | Parameter read | | ||
