projects:crazyflie:firmware:comm_protocol [2013-08-23 19:54] ledvinap |
projects:crazyflie:firmware:comm_protocol [2021-06-24 16:49] kimberly |
CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | ||
Line 124: | Line 127: | ||
Line 130: | Line 133: | ||
- | | TOC CRC and count | 0 | 0x01 Request the TOC CRC and item count | | + | | TOC CRC and count | 0 | 0x01 (CMD_GET_INFO) |
Line 166: | Line 170: | ||
- | with ID omitted | + | |
+ | [optional] | ||
+ | (or any higher) | ||
Line 183: | Line 193: | ||
+ | | Reset log | ||
^ **Byte** | ^ **Byte** | ||
Line 207: | Line 220: | ||
Line 218: | Line 232: | ||
Line 228: | Line 242: | ||
7 | 7 | ||
Line 237: | Line 252: | ||
7 | 7 | ||
+ | | 0xff | | ||
Line 253: | Line 271: | ||
- | | 0x00 | + | | |
- | | 0x01 | + | | |
- | | 0xFF | + | | |
[DONE] | [DONE] | ||
Line 287: | Line 306: | ||
+ | ^ **Byte** | ||
Line 329: | Line 355: | ||
- | **TODO** | + | |
- | **TODO** | + | ^ |
+ | | Parameter read | | ||
