projects:crazyflie:firmware:comm_protocol [2013-09-16 19:29] ledvinap [Logging] |
projects:crazyflie:firmware:comm_protocol [2021-06-24 16:49] kimberly |
CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | ||
Line 124: | Line 127: | ||
Line 136: | Line 139: | ||
- | | TOC CRC and count | 0 | 0x01 Request the TOC CRC and item count | | + | | TOC CRC and count | 0 | 0x01 (CMD_GET_INFO) |
Line 183: | Line 186: | ||
Line 189: | Line 193: | ||
- | | Append to log | + | | Append to existing |
- | | Delete a log | | + | | Delete a log block | |
- | | Start a log block | | + | | Start a log block |
- | | Stop a log block | | + | | Stop a log block |
- | | Reset log | | + | | Reset log |
Line 209: | Line 213: | ||
^ **Byte** | ^ **Byte** | ||
Line 238: | Line 242: | ||
- | TOC variable request (Storage type is ignored): | + | TOC variable request (Storage type is ignored, it is taken from Crazyflie internal TOC): |
7 | 7 | ||
Line 267: | Line 271: | ||
- | == List of return codes ( errno.h codes are used ) == | + | == List of return codes ( errno.h codes are used, returned values are positive |
- | | 0 | No error | | + | | 0 | No error | |
- | | ENOENT (2) | Block or variable not found | | + | | ENOENT (2) |
- | | E2BIG (7) | Log block is too long | | + | | E2BIG (7) | Log block is too long | |
- | | ENOEXEC (8) | unknown | + | | ENOEXEC (8) | Unknown |
| ENOMEM (12) | No memory to allocate Log Block or Log Item | | | ENOMEM (12) | No memory to allocate Log Block or Log Item | | ||
Line 302: | Line 306: | ||
+ | ^ **Byte** | ||
- | Adding a log block 0xbb logging variable ID 0x55 at 100ms interval and of type uint16: | + | Adding a log block 0xbb at 100ms interval |
Computer -> CF : 0x[5,1] 0x00 0xbb 0x02 0x55 // create logging block | Computer -> CF : 0x[5,1] 0x00 0xbb 0x02 0x55 // create logging block | ||
- | Computer -> CF : 0x[5, | + | Computer -> CF : 0x[5, |
- | Receiving a log block 0xbb 1300ms | + | Receiving a log block 0xbb with timestamp 130.532s (0x1FDE4 ms), logging |
- | CF -> Computer : 0x[5,2] 0xBB 0xA3 0xA2 0xA1 0xBA 0xBE | + | CF -> Computer : 0x[5,2] 0xBB 0xE4 0xFD 0x01 0xBE 0xBA |
Line 344: | Line 355: | ||
- | **TODO** | + | |
- | **TODO** | + | ^ |
+ | | Parameter read | | ||
