projects:crazyflie:firmware:comm_protocol [2013-04-02 15:43] arnaud [Packet structure] |
CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | ||
Line 21: | Line 24: | ||
^ **Link** | ^ **Link** | ||
Line 28: | Line 31: | ||
Line 61: | Line 64: | ||
Line 103: | Line 106: | ||
+ | === Examples === | ||
+ | To send setpoints to the [[projects: | ||
+ | 0xaa 0xaa 0x30 0x0e 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x3e | ||
+ | To ping Crazyflie: | ||
===== Ports ===== | ===== Ports ===== | ||
Line 113: | Line 127: | ||
Line 119: | Line 133: | ||
Line 155: | Line 170: | ||
- | with ID omitted | + | |
+ | [optional] | ||
+ | (or any higher) | ||
Line 172: | Line 193: | ||
+ | | Reset log | ||
^ **Byte** | ^ **Byte** | ||
Line 196: | Line 220: | ||
Line 207: | Line 232: | ||
Line 217: | Line 242: | ||
7 | 7 | ||
Line 226: | Line 252: | ||
7 | 7 | ||
+ | | 0xff | | ||
Line 242: | Line 271: | ||
- | | 0x00 | + | | |
- | | 0x01 | + | | |
- | | 0xFF | + | | |
[DONE] | [DONE] | ||
Line 276: | Line 306: | ||
+ | ^ **Byte** | ||
Line 318: | Line 355: | ||
- | **TODO** | + | |
- | **TODO** | + | ^ |
+ | | Parameter read | | ||
