projects:crazyflie:firmware:comm_protocol [2014-05-09 04:21] fred [Logging] fixed tiny but significant typo in hex string that cost me an hour of debugging |
CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | CRTP is the protocol used to communicate with Crazyflie. Is originally stands for //Crazy RealTime Protocol//. The protocol permits to communicate independently with the copter subsystem and would have the capability to handle packet priorities. | ||
Line 323: | Line 326: | ||
Line 352: | Line 355: | ||
- | **TODO** | + | |
- | **TODO** | + | ^ |
+ | | Parameter read | | ||
