projects:crazyflie:firmware:log [2012-10-07 13:37] arnaud created |
projects:crazyflie:firmware:log [2012-11-11 18:19] arnaud [Table of content access] |
====== Crazyflie LOG subsystem ====== | ====== Crazyflie LOG subsystem ====== | ||
- | The Crazyflie log system is design in such a way that the copter firmware is mostly independant from the client and all information required to get the log system to work are communicated at connection time. The copter contains a table of content of all the variable possible to log. The client retrieve the list at connection time. The client then program in the copter log packets (ie. list of variable to log at the same time) to be sent back at regular interval. | + | The purpose of the logging is to be able to log variables that are available in the copter during runtime. |
This mechanism is used both for regular log operation (ie. user requested log to inspect and debug flight data) but also to update indication in the GUI application. | This mechanism is used both for regular log operation (ie. user requested log to inspect and debug flight data) but also to update indication in the GUI application. | ||
+ | Each variable to log is contained in a group group and has a name. The system is designed to make it easy to add a log variable in the Firmware and have it available in the ground station GUI: | ||
+ | ===== Communication protocol ===== | ||
+ | The log port is separated in 3 channels: | ||
+ | ^ **Port** | ||
+ | ==== Table of content access ==== | ||
+ | This channel is used to access the loggable variables table of content. | ||
+ | The first byte of each messages correspond a command. All communication on this port are initated by the client and all answer from the copter will contain the same command byte. | ||
+ | ^ TOC command byte ^ Command | ||
+ | | 0 | GET_ITEM | ||
+ | | 1 | GET_INFO | ||
+ | === Get TOC item === | ||
+ | The GET_ITEM TOC command permits to retrieved the log variables name, group and types from the copter. This command is intended to be requested from all the ID from 0 to LOG_LEN (see GET_INFO). | ||
+ | Request (PC to Copter): | ||
+ | | GET_ITEM (0) | ID | | ||
+ | Length | ||
+ | Answer (Copter to PC): | ||
+ | | GET_ITEM (0) | ID | If index out of range | ||
+ | | GET_ITEM (0) | ID | Type | | ||
+ | Length | ||
+ | ^ Byte ^ Request fields ^ Content | ||
+ | | 1 | ID | ID of the item to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command) | | ||
+ | ^ Byte ^ Answer fields | ||
+ | | 1 | ID | ID of the item returned | ||
+ | | 2 | Type | Variable type of the element. See variable types list | | ||
+ | | 3.. | Group | Null-terminated string containing variable group | | ||
+ | | .. | Name | Null-terminated string containing the variable name | | ||
+ | Type, group and name are not sent if the required ID is higher than TOC_LEN-1. | ||
+ | === Get Info === | ||
+ | The get info command is intended to be requested first when connecting to the copter. This permits to know the number of variable, the limitations of the log implementation and the fingerprint of the log variables. | ||
+ | | GET_INFO (1) | | ||
+ | Length | ||
+ | | GET_INFO (1) | LOG_LEN | LOG_CRC | LOG_MAX_PACKET | LOG_MAX_OPS | | ||
+ | Length | ||
+ | | 0 | GET_INFO | ||
+ | | 1 | LOG_LEN | ||
+ | | 2 | LOG_CRC | ||
+ | | 6 | LOG_MAX_PACKET | Maximum number of log packets that can be programmed in the copter | | ||
+ | | 7 | LOG_MAX_OPS | ||
+ | ==== Log control ==== | ||
+ | The log control channel permits to setup, activate, deactivate and remove log packets. Like the TOC access channel the first data byte represents a command. | ||
+ | ^ Control command byte ^ Command | ||
+ | | 0 | CREATE_BLOCK | ||
+ | | 1 | APPEND_BLOCK | ||
+ | | 2 | DELETE_BLOCK | ||
+ | | 3 | START_BLOCK | ||
+ | | 4 | STOP_BLOCK | ||
