User Tools
Site Tools
projects:crazyflie:firmware:log
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:firmware:log [2012-12-09 22:31]
arnaud [Log control]
projects:crazyflie:firmware:log [2021-06-24 16:49] (current)
Line 1: Line 1:
 +</WRAP>
 ====== Crazyflie LOG subsystem ====== ====== Crazyflie LOG subsystem ======
-The purpose of the logging is to be able to log variables that are available in the copter during runtime. The Crazyflie log system is design in such a way that the copter firmware is mostly independant from the client and all information required to get the log system to work are communicated at connection time. The copter contains a table of content of all the variable possible to log. The client retrieve the list at connection time. The client then program in the copter log packets (ie. list of variable to log at the same time) to be sent back at regular interval.+The purpose of the logging is to be able to log variables that are available in the copter during runtime. The Crazyflie log system is design in such a way that the copter firmware is mostly independent from the client and all information required to get the log system to work are communicated at connection time. The copter contains a table of content of all the variable possible to log. The client retrieve the list at connection time. The client then program in the copter log packets (ie. list of variable to log at the same time) to be sent back at regular interval.
 This mechanism is used both for regular log operation (ie. user requested log to inspect and debug flight data) but also to update indication in the GUI application. This mechanism is used both for regular log operation (ie. user requested log to inspect and debug flight data) but also to update indication in the GUI application.
Line 9: Line 12:
 {{:projects:crazyflie:firmware:logmagic.png?800|}} {{:projects:crazyflie:firmware:logmagic.png?800|}}
-===== Communication protocol =====+===== Firmware usage =====
-The log port is separated in 3 channels:+A couple of macros are declared in //log.h// to define new log variables. All log variables should be in a log group. Example:
-^ **Port**  ^ **Channel** ^ **Function**      ^ +<code style="c"
-|            0        | Table of content access | +LOG_GROUP_START(stabilizer
-|            1        | Log control | +LOG_ADD(LOG_FLOAT, roll, &eulerRollActual
-|            2        | Log data | +LOG_ADD(LOG_FLOATpitch&eulerPitchActual
- +LOG_ADD(LOG_FLOATyaw&eulerYawActual)
-==== Table of content access ==== +LOG_GROUP_STOP(stabilizer)
-This channel is used to access the loggable variables table of content. +
-The first byte of each messages correspond a command. All communication on this port are initated by the client and all answer from the copter will contain the same command byte. +
-^ TOC command byte ^ Command   ^ Operation ^ +
-|                0 | GET_ITEM  | Get an item from the TOC | +
-|                1 | GET_INFO  | Get information about the TOC and the LOG subsystem implementation | +
-=== Get TOC item === +
-The GET_ITEM TOC command permits to retrieved the log variables name, group and types from the copter. This command is intended to be requested from all the ID from 0 to LOG_LEN (see GET_INFO). +
-<code> +
-Request (PC to Copter): +
-        | GET_ITEM (0| ID | +
-Length                 1 +
-Answer (Copter to PC): +
-        | GET_ITEM (0) | ID |                                        If index out of range +
-        | GET_ITEM (0) | ID | Type |   Group    |     Name         If returning Item +
-Length        1          1        < Null terminated strings > +
-</code> +
-^ Byte ^ Request fields ^ Content                             ^ +
-|  0   | GET_ITEM       | At 0 for GET_ITEM operation | +
-|  1   | ID             | ID of the item to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command) | +
-^ Byte ^ Answer fields  ^ Content                             ^ +
-|  0   | GET_ITEM       | 0 for GET_ITEM operation | +
-|  1   | ID             | ID of the item returned +
-|  2   | Type           | Variable type of the element. See variable types list | +
-|  3..  | Group          | Null-terminated string containing variable group | +
-|  ..  | Name           | Null-terminated string containing the variable name | +
-Typegroup and name are not sent if the required ID is higher than TOC_LEN-1. +
-=== Get Info === +
-The get info command is intended to be requested first when connecting to the copter. This permits to know the number of variablethe limitations of the log implementation and the fingerprint of the log variables. +
-<code> +
-Request (PC to Copter)+
-        | GET_INFO (1) | +
-Length         1 +
-        | GET_INFO (1) | LOG_LEN | LOG_CRC |  LOG_MAX_PACKET | LOG_MAX_OPS | +
-Length        1                                               1 +
-</code> +
-|  0   | GET_INFO       | At 1 for GET_INFO operation | +
-|  0   | GET_INFO       | 1 for GET_INFO operation | +
-|  1   | LOG_LEN        | Number of log items contained in the log table of content | +
-|  2   | LOG_CRC        | CRC values of the log TOC memory content. This is a fingerprint of the copter build that can be used to cache the TOC | +
-|  6   | LOG_MAX_PACKET | Maximum number of log packets that can be programmed in the copter | +
-|  7   | LOG_MAX_OPS    | Maximum number of operation programmable in the copter. An operation is one log variable retrieval programming | +
-==== Log control ==== +
-The log control channel permits to setupactivatedeactivate and remove log packets. Like the TOC access channel the first data byte represents a command. +
-^ Control command byte ^ Command       ^ Operation ^ +
-|                    0 | CREATE_BLOCK  | Create a new log block | +
-|                    1 | APPEND_BLOCK  | Append variables to an existing block | +
-|                    2 | DELETE_BLOCK  | Delete log block | +
-|                    3 | START_BLOCK   | Enable log block transmition | +
-|                    4 | STOP_BLOCK    | Disable log block transmition | +
-=== Create block === +
-=== Append variable to block === +
-=== Delete block === +
-=== Start block === +
-=== Stop block === +
-==== Log data ==== +
-The log data channel is used by the copter to send the log blocks at the programmed rate. The packet format is +
-<code> +
-Answer (Copter to PC)+
-        | BLOC_ID | TIME_STAMP | LOG VARIABLE VALUES | +
-Length        1          3           0 to 28+
 </code> </code>
-Byte Answer fields  ^ Content                             +Macro                        Usage
-   BLOCK_ID       | ID of the block          +LOG_GROUP_START(grp_name)    Start a log group named //grp_name//
-   ID             | Timestamp in ms from the copter startup as a little-endian 3 bytes integer +LOG_GROUP_STOP(grp_name)     Stop log group declaration for group //grp_name//
- 4..  Log variable values | Packed log values in little endian format +LOG_ADD(type, name, address) Add a log variable. //type// is the variable type (see bellow), //name// is the name as it will be sent to the ground and //address// is the memory address of the variable |
 +^ Type defines ^ Corresponding C99 type ^ Note ^
 +| LOG_UINT8    | uint8_t                |      |
 +| LOG_UINT16   | uint16_t                    |
 +| LOG_UINT32   | uint32_t                    |
 +| LOG_INT8     | int8_t                      |
 +| LOG_INT16    | int16_t                |      |
 +| LOG_INT32    | int32_t                |      |
 +| LOG_FLOAT    | float                  | IEEE 754 binary32 (single precision float) |
 +| LOG_FP16     | //N/A?//               | IEEE 754 binary16, intended for log report only (not in memory) |
projects/crazyflie/firmware/log.1355088699.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
