projects:crazyflie:hardware:explained [2012-12-03 22:05] tobias [Expansion header] |
projects:crazyflie:hardware:explained [2014-09-29 07:23] chad [LiPo] capitalization |
Line 8: | Line 8: | ||
===== Battery ===== | ===== Battery ===== | ||
- | The battery we use is of the type LiPo (Lithium-Polymer). They are currently the most popular battery type for R/C use. The LiPo is hoverer | + | The battery we use is of the type LiPo (Lithium-Polymer). They are currently the most popular battery type for R/C use. The LiPo is however |
==== PCM ==== | ==== PCM ==== | ||
Line 25: | Line 25: | ||
Line 35: | Line 35: | ||
Specification: | Specification: | ||
- | || Model || Voltage (V) || Capacity (mAH) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continues Discharge Rate || Burst (≤5S)|| | + | || Model || Voltage (V) || Capacity (mAh) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continues Discharge Rate || Burst (≤5S)|| |
|| 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C || | || 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C || | ||
Line 47: | Line 47: | ||
Line 66: | Line 81: | ||
Header pin description | Header pin description | ||
- | || Pin nr || Name || Description | + | ^^ Pin nr ^^ Name ^^ Description |
|| 1 || VCC || Digital supply voltage || | || 1 || VCC || Digital supply voltage || | ||
|| 2 || TMS || Test Mode Select || | || 2 || TMS || Test Mode Select || | ||
Line 77: | Line 92: | ||
|| 9 || DGND || Digital ground || | || 9 || DGND || Digital ground || | ||
|| 10 || SNRST || System reset || | || 10 || SNRST || System reset || | ||
+ | || 11 || EXT_SPI_CS/ | ||
+ | || 12 || EXT_SPI_MOSI/ | ||
+ | || 13 || EXT_SPI_SCK/ | ||
+ | || 14 || EXT_SPI_MISO/ | ||
+ | || 15 || VCC || Digital supply voltage || | ||
+ | || 16 || VCOM || Battery/USB voltage || | ||
+ | || 17 || DGND || Digital ground || | ||
+ | || 18 || DGND || Digital ground || | ||
+ | || 19 || AGND || Analogue ground|| | ||
+ | || 20 || VCCA || Analogue supply || | ||
===== 2.4GHz radio ===== | ===== 2.4GHz radio ===== | ||
+ | The motor driver, as we use brushed motors, is a simple pull down mosfet as shown in the schematics. There is also a free-wheel diode to take the Back-EMF spikes generated by the motor during PWM-ing. | ||
+ | The mosfet we choose is the PMV31XN in a SOT-23 package. It can handle a lot of power and should be good for at least 3A each. The most important property of the mosfet though might be the on resistance (Rdson) since it effects the amount of power the motors can make use of. We measured the PMV31XN Rdson at 2.8V G-D voltage and 0.8A D-S current to be ~40 mOhm. | ||
+ | **Electrical** | ||
+ | **Mechanical** | ||
+ | || Weight || 1.7 g approx.|| | ||
