projects:crazyflie:hardware:explained [2012-12-03 22:13] tobias [Expansion header] |
projects:crazyflie:hardware:explained [2013-01-22 14:43] tobias [Power management] |
Line 47: | Line 47: | ||
Line 66: | Line 81: | ||
Header pin description | Header pin description | ||
- | || Pin nr || Name || Description | + | ^^ Pin nr ^^ Name ^^ Description |
|| 1 || VCC || Digital supply voltage || | || 1 || VCC || Digital supply voltage || | ||
|| 2 || TMS || Test Mode Select || | || 2 || TMS || Test Mode Select || | ||
Line 91: | Line 106: | ||
+ | The motor driver, as we use brushed motors, is a simple pull down mosfet as shown in the schematics. There is also a free-wheel diode to take the Back-EMF spikes generated by the motor during PWM-ing. | ||
+ | The mosfet we choose is the PMV31XN in a SOT-23 package. It can handle a lot of power and should be good for at least 3A each. The most important property of the mosfet though might be the on resistance (Rdson) since it effects the amount of power the motors can make use of. We measured the PMV31XN Rdson at 2.8V G-D voltage and 0.8A D-S current to be ~40 mOhm. | ||
+ | **Electrical** | ||
+ | **Mechanical** | ||
+ | || Weight || 1.6g approx.|| | ||
