projects:crazyflie:hardware:explained [2012-12-03 23:32] tobias [Motor drivers] |
projects:crazyflie:hardware:explained [2015-07-15 16:31] 127.0.0.1 external edit |
Line 8: | Line 8: | ||
===== Battery ===== | ===== Battery ===== | ||
- | The battery we use is of the type LiPo (Lithium-Polymer). They are currently the most popular battery type for R/C use. The LiPo is hoverer | + | The battery we use is of the type LiPo (Lithium-Polymer). They are currently the most popular battery type for R/C use. The LiPo is however |
==== PCM ==== | ==== PCM ==== | ||
Line 25: | Line 25: | ||
Line 35: | Line 35: | ||
Specification: | Specification: | ||
- | || Model || Voltage (V) || Capacity (mAH) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continues | + | || Model || Voltage (V) || Capacity (mAh) || Thickness (±0.2) || Width (±0.5) || Height (±0.5) || Weight (g) || Charge Rate || Continuous |
|| 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C || | || 671723HS25C || 3.7 || 170 || 6.9 ||17 || 23 || 3.9 || 1C-5C || 25C (≥ 80%) || 50C || | ||
Line 47: | Line 47: | ||
Line 61: | Line 76: | ||
===== Expansion header ===== | ===== Expansion header ===== | ||
- | The expansion header is located on the left side of the Crazyflie. It is a 10x2 pin 1.27mm (0.05" | + | The expansion header is located on the left side of the Crazyflie. It is a 10x2 pin 1.27mm (0.05" |
The header is divided into two parts. The JTAG part, pin 1 to 10, and the buss/power part, pin 11 to 20. The UART RX/TX is located on the JTAG part because on many FTDI based JTAGs it is possible to use one channel for serial communication which can be very handy when debugging. | The header is divided into two parts. The JTAG part, pin 1 to 10, and the buss/power part, pin 11 to 20. The UART RX/TX is located on the JTAG part because on many FTDI based JTAGs it is possible to use one channel for serial communication which can be very handy when debugging. | ||
Header pin description | Header pin description | ||
- | || Pin nr || Name || Description | + | ^^ Pin nr ^^ Name ^^ Description |
|| 1 || VCC || Digital supply voltage || | || 1 || VCC || Digital supply voltage || | ||
|| 2 || TMS || Test Mode Select || | || 2 || TMS || Test Mode Select || | ||
Line 78: | Line 93: | ||
|| 10 || SNRST || System reset || | || 10 || SNRST || System reset || | ||
|| 11 || EXT_SPI_CS/ | || 11 || EXT_SPI_CS/ | ||
- | || 12 || EXT_SPI_MOSI/ | + | || 12 || EXT_SPI_MOSI/ |
- | || 13 || EXT_SPI_SCK/ | + | || 13 || EXT_SPI_SCK/ |
- | || 14 || EXT_SPI_MISO/ | + | || 14 || EXT_SPI_MISO/ |
|| 15 || VCC || Digital supply voltage || | || 15 || VCC || Digital supply voltage || | ||
|| 16 || VCOM || Battery/USB voltage || | || 16 || VCOM || Battery/USB voltage || | ||
Line 96: | Line 111: | ||
The mosfet we choose is the PMV31XN in a SOT-23 package. It can handle a lot of power and should be good for at least 3A each. The most important property of the mosfet though might be the on resistance (Rdson) since it effects the amount of power the motors can make use of. We measured the PMV31XN Rdson at 2.8V G-D voltage and 0.8A D-S current to be ~40 mOhm. | The mosfet we choose is the PMV31XN in a SOT-23 package. It can handle a lot of power and should be good for at least 3A each. The most important property of the mosfet though might be the on resistance (Rdson) since it effects the amount of power the motors can make use of. We measured the PMV31XN Rdson at 2.8V G-D voltage and 0.8A D-S current to be ~40 mOhm. | ||
+ | **Electrical** | ||
+ | **Mechanical** | ||
+ | || Weight || 1.7 g approx.|| | ||
