projects:crazyflie:hardware:explained [2013-01-12 14:22] tobias [Motors] |
projects:crazyflie:hardware:explained [2013-01-22 14:44] tobias [Specification] |
Line 47: | Line 47: | ||
Line 98: | Line 113: | ||
We use a coreless brushed DC motor 6x15mm. | We use a coreless brushed DC motor 6x15mm. | ||
- | Specification | + | ==== Specification |
- | || Rated voltage || 4.2 V Max || | + | **Electrical** |
|| Description || Value || | || Description || Value || | ||
|| No load speed || 45000 ±15% RPM || | || No load speed || 45000 ±15% RPM || | ||
|| No load current || 80 mA Max || | || No load current || 80 mA Max || | ||
Line 106: | Line 123: | ||
|| Rated load speed || 21000 ±15% RPM || | || Rated load speed || 21000 ±15% RPM || | ||
|| Rated load current || 810 mA Max || | || Rated load current || 810 mA Max || | ||
- | || Weight | + | || Resistance |
- | || Internal resistance | + | |
+ | **Mechanical** | ||
+ | || Motor diameter | ||
+ | || Weight || 1.7 g approx.|| | ||
