projects:crazyflie:hardware:explained [2013-01-12 15:54] tobias [Specification] |
projects:crazyflie:hardware:explained [2013-06-26 08:52] tobias [PCM] |
Line 25: | Line 25: | ||
Line 47: | Line 47: | ||
Line 115: | Line 130: | ||
|| Motor diameter || 6 ± 0.05 mm || | || Motor diameter || 6 ± 0.05 mm || | ||
|| Motor length || 15 mm || | || Motor length || 15 mm || | ||
- | || Weight || 1.6g approx.|| | + | || Weight || 1.7 g approx.|| |
