projects:crazyflie:hardware:explained [2013-01-22 14:43] tobias [Power management] |
projects:crazyflie:hardware:explained [2014-04-11 15:40] arnaud [Expansion header] |
Line 25: | Line 25: | ||
Line 93: | Line 93: | ||
|| 10 || SNRST || System reset || | || 10 || SNRST || System reset || | ||
|| 11 || EXT_SPI_CS/ | || 11 || EXT_SPI_CS/ | ||
- | || 12 || EXT_SPI_MOSI/ | + | || 12 || EXT_SPI_MOSI/ |
- | || 13 || EXT_SPI_SCK/ | + | || 13 || EXT_SPI_SCK/ |
- | || 14 || EXT_SPI_MISO/ | + | || 14 || EXT_SPI_MISO/ |
|| 15 || VCC || Digital supply voltage || | || 15 || VCC || Digital supply voltage || | ||
|| 16 || VCOM || Battery/USB voltage || | || 16 || VCOM || Battery/USB voltage || | ||
Line 130: | Line 130: | ||
|| Motor diameter || 6 ± 0.05 mm || | || Motor diameter || 6 ± 0.05 mm || | ||
|| Motor length || 15 mm || | || Motor length || 15 mm || | ||
- | || Weight || 1.6g approx.|| | + | || Weight || 1.7 g approx.|| |
