projects:crazyflie:index [2013-10-10 00:18] fred Added Android section |
projects:crazyflie:index [2016-03-29 16:36] bjorn [Expansion boards] |
Line 7: | Line 7: | ||
- | * Radio bootloader which enables wireless [[projects:crazyflie:pc_utils:qt_ui# | + | * Radio bootloader which enables wireless [[doc:crazyflie:client:pycfclient: |
Line 16: | Line 16: | ||
+ | * [[doc: | ||
Line 26: | Line 27: | ||
+ | * [[doc: | ||
Line 32: | Line 34: | ||
===== Android Environment ===== | ===== Android Environment ===== | ||
- | * [[projects:crazyflie:android_client:dev_guide|Android client dev. guide]]: Development guide for the Crazyflie Android client | + | * [[doc:crazyflie:dev:env:android|Android client dev. guide]]: Development guide for the Crazyflie Android client |
Line 41: | Line 43: | ||
+ | * [[projects: | ||
- | * [[projects: | + | |
