projects:crazyflie:index [2015-01-29 13:49] 161.69.163.20 Links adapted because of a move operation |
projects:crazyflie:index [2021-06-24 16:49] kimberly |
+ | ====== Crazyflie 1.0 ====== | ||
+ | The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors. | ||
+ | **Features** | ||
+ | * Small and lightweight, | ||
+ | * Flight time up to 7 minutes with standard 170mAh Li-Po battery | ||
+ | * Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery | ||
+ | * On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle | ||
+ | * Radio bootloader which enables wireless [[doc: | ||
+ | * Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM) | ||
+ | * 3-axis high-performance MEMs gyros with 3-axis accelerometer: | ||
+ | * Available footprints to manually solder magnetometer HMC5883L/ | ||
+ | * Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included) | ||
+ | * 4-layer low noise PCB design with separate voltage regulators for digital and analog supply | ||
+ | ====== Using the Crazyflie ====== | ||
+ | * [[projects: | ||
+ | * [[[[misc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | ===== PC/Host Environment ===== | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | ===== Firmware ===== | ||
+ | ===== Electronics ===== | ||
+ | * [[misc: | ||
