projects:crazyflie:index [2012-02-22 16:15] macke [Using the Crazyflie] |
| - | ====== Crazyflie ====== | + | <WRAP center round important 60%> |
| - | This is the home for documentation of the Crazyflie quadcopter. | + | This page has deprecated and will be archived. Please go to [[https:// |
| + | ====== Crazyflie | ||
| + | The Crazyflie | ||
| - | ===== Using the Crazyflie ===== | + | **Features** |
| - | * [[[projects: | + | * Small and lightweight, |
| - | * [[[projects: | + | * Flight time up to 7 minutes with standard 170mAh Li-Po battery |
| - | * [[[projects: | + | * Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery |
| + | * On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle | ||
| + | * Radio bootloader which enables wireless [[doc: | ||
| + | * Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM) | ||
| + | * 3-axis high-performance MEMs gyros with 3-axis accelerometer: | ||
| + | * Available footprints to manually solder magnetometer HMC5883L/ | ||
| + | * Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included) | ||
| + | * 4-layer low noise PCB design with separate voltage regulators for digital and analog supply | ||
| + | ====== Using the Crazyflie | ||
| + | * [[projects: | ||
| + | * [[[[misc: | ||
| + | * [[doc: | ||
| + | * [[doc: | ||
| + | ====== Development ====== | ||
| - | ===== PC Environment ===== | + | ===== PC/Host Environment ===== |
| - | * [[projects:crazyflie:pc_utils:index|PC Utilities]]: For controlling and logging | + | * [[doc:crazyflie:api:python:index|Crazyflie Python Library]]: Documentation for the Python library used to communicate with the Crazyflie |
| - | ===== Mechanics | + | ===== Android Environment |
| - | * [[[projects:crazyflie:mechanics:index|Mechanics]]: How to attach | + | * [[doc:crazyflie:dev:env:android|Android client dev. guide]]: Development guide for the Crazyflie Android client |
| - | ===== Crazyflie | + | ===== Firmware ===== |
| - | ===== Crazyflie hardware ===== | + | |
| - | ===== Expansion boards | + | ===== Electronics |
| - | * [[projects: | + | * [[misc: |
| + | * [[projects:crazyflie: | ||
