projects:crazyflie:index [2013-02-01 00:24] macke |
| - | ====== Crazyflie | + | <WRAP center round important 60%> |
| - | The Crazyflie is a tiny quadcopter often refereed | + | This page has deprecated and will be archived. Please go to [[https:// |
| + | ====== Crazyflie | ||
| + | The Crazyflie is a tiny quadcopter often referred | ||
| **Features** | **Features** | ||
| Line 7: | Line 10: | ||
| * Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery | * Standard micro-USB connector for charging which takes ~20min for the stock 170mAh Li-Po battery | ||
| * On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle | * On-board low-energy radio@1mW based on the nRF24L01+ chip. Up to 80m range (environment dependent) when using the Crazyradio USB dongle | ||
| - | * Radio bootloader which enabled | + | * Radio bootloader which enables |
| * Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM) | * Powerful 32 bit MCU: STM32F103CB @ 72 MHz (128kb flash, 20kb RAM) | ||
| * 3-axis high-performance MEMs gyros with 3-axis accelerometer: | * 3-axis high-performance MEMs gyros with 3-axis accelerometer: | ||
| Line 13: | Line 16: | ||
| * Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included) | * Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included) | ||
| * 4-layer low noise PCB design with separate voltage regulators for digital and analog supply | * 4-layer low noise PCB design with separate voltage regulators for digital and analog supply | ||
| ====== Using the Crazyflie ====== | ====== Using the Crazyflie ====== | ||
| - | * [[projects: | + | |
| - | * [[projects:crazyflie:pc_utils:qt_ui|GUI Application]]: | + | |
| + | * [[doc:crazyflie:client:pycfclient: | ||
| + | * [[projects: | ||
| - | * [[projects:crazyflie:mechanics: | + | * [[projects:virtualmachine:index | Bitcraze Virtual Machine |
| + | * [[doc: | ||
| ====== Development ====== | ====== Development ====== | ||
| - | * [[projects:crazyflie:wishlist| Wishlist and expansion ideas]]: Our and other peoples wishlists, project ideas and possible expansions | + | * [[projects:contribution:index | How to contribute to the project]] |
| ===== PC/Host Environment ===== | ===== PC/Host Environment ===== | ||
| - | * [[projects:crazyflie:pc_utils:pylib|Crazyflie Python Library]]: Documentation for the Python library used to communicate with the Crazyflie | + | * [[doc:crazyflie:api:python: |
| + | ===== Android Environment ===== | ||
| + | * [[doc: | ||
| ===== Firmware ===== | ===== Firmware ===== | ||
| Line 37: | Line 44: | ||
| ===== Electronics ===== | ===== Electronics ===== | ||
| - | * [[projects: | + | * [[misc: |
| - | ===== Expansion boards ===== | ||
| - | * [[projects: | ||
