projects:crazyflie:index [2013-05-09 16:45] jweather [Using the Crazyflie] |
- | ====== Crazyflie | + | <WRAP center round important 60%> |
- | The Crazyflie is a tiny quadcopter often refereed | + | This page has deprecated and will be archived. Please go to [[https:// |
+ | ====== Crazyflie | ||
+ | The Crazyflie is a tiny quadcopter often referred | ||
**Features** | **Features** | ||
Line 7: | Line 10: | ||
- | * Radio bootloader which enabled | + | * Radio bootloader which enables |
Line 16: | Line 19: | ||
+ | * [[doc: | ||
+ | * [[projects: | ||
- | * [[projects: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
Line 38: | Line 44: | ||
- | * [[projects: | + | |
