projects:crazyflie:index [2016-03-29 16:36] bjorn [Expansion boards] |
- | ====== Crazyflie | + | <WRAP center round important 60%> |
+ | ====== Crazyflie | ||
The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors. | The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors. | ||
Line 25: | Line 28: | ||
- | * [[projects: | ||
* [[doc: | * [[doc: | ||
