projects:crazyflie:index [2013-05-02 09:17] macke |
projects:crazyflie:index [2016-03-29 16:36] bjorn [Using the Crazyflie] |
====== Crazyflie Nano Quadcopter ====== | ====== Crazyflie Nano Quadcopter ====== | ||
- | The Crazyflie is a tiny quadcopter often refereed | + | The Crazyflie is a tiny quadcopter often referred |
**Features** | **Features** | ||
Line 7: | Line 7: | ||
- | * Radio bootloader which enabled | + | * Radio bootloader which enables |
Line 13: | Line 13: | ||
* Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included) | * Expansion header 2×10 pins 1.27mm (0.05”) pitch including power, I2C/UART, SPI/ADC. Header also contains ARM Cortex 10-pin JTAG (header not included) | ||
* 4-layer low noise PCB design with separate voltage regulators for digital and analog supply | * 4-layer low noise PCB design with separate voltage regulators for digital and analog supply | ||
====== Using the Crazyflie ====== | ====== Using the Crazyflie ====== | ||
+ | * [[doc: | ||
+ | * [[projects: | ||
- | * [[projects: | ||
+ | * [[doc: | ||
Line 33: | Line 33: | ||
+ | * [[doc: | ||
Line 39: | Line 42: | ||
- | ===== Expansion boards ===== | ||
- | * [[projects: |
